memory foam for bedding
#11
Posted 04 August 2011 - 01:12 AM
#12
Posted 19 March 2012 - 05:02 AM
As I said in my previous post, I found the foam of the bed way too firm and I was not sleeping well. After multiple tests, I found a foam be I am very happy with:
3 inch of ILD 34 foam with 1 inch of ILD 24 foam on top.
4 inch of ILD 34 was too firm and I was bottoming out on 4 inches of 24. Maybe 2 inch of each would be great, I didn't try, I was worried I would bottom out. I am 190 pounds and I like beds on the firmer side but with some softness.
I ordered from foam order because of their return policy on CUSTOM CUT foam: if you don't like your custom cut foam, they take it back with a 15% restocking fee (totally reasonable for custom cut IMO). I did do a return and they were very nice to me when I did so. If you are in the bay area, I highly recommend them.
They have more expensive foam warrantied 15 years (V34 and V24) and less expensive foam warrantied 5 years (C34 and C24). The V24 is hard to find on their web site, it is under "Foam filler for Down envelope".
The dimensions I got for my 2011 hawk were slightly smaller than the foam FWC put it, based on their feedback, and it worked out well. I got for the large one:
Width: 76.5 in, Depth: 47.5 in
And for the small ones:
Width: 38.25 in, Depth: 16.125 in
They will glue both pieces of foam together for free.
House of Foam in Palo Alto has ILD 30 foam which may be great firmness as is and is cheap, but they don't warranty their foam and don't accept returns for custom cut.
I considered Latex foam which is what I use for my bed at home but:
- it is quite heavy
- it is very inflammable and require fire retardant cover (Stan, do you know if the fabric FWC uses is fire retardant?)
- the company below would only warranty cuts within one inch precision!
- no return policy with the company below
If you want to go with latex, this company has latex foam for cheap and I like the latex I got from them for my bed (I got 6 inch ILD 36 and one inch ILD 20 if you are curious!):
http://www.foambymail.com
On the plus side, it doesn't have all the fire retardant chemicals of other foams.
It would be great if FWC had an option for "premium" foam, or an option for no foam.
If you want the foam I got from FWC, you can come get it in San Francisco for cheap. Send private message for details.
Hope this helps,
Herve
Hello. I am a brand new owner of a Hawk. Wow!!! Will post pics soon.
The bed is really hard. I see 3 options:
1/ replacing the foam inside the cushions with softer material (such as what you suggest: 1/2" of memory foam on top of 2 1/2"s of standard foam) => need to cut the foam to fit in the multiple cushions
2/ adding a memory foam or latex on top of the existing cushions => where to store it after sliding the bed...
3/ getting a padded sheet => not as much padding but may be enough
Which option have people pursued and with what success?
BTW I got the "king slide" option so I can sleep in the same direction as the truck. I am tall (6'3") so this option rocks!
Herve
#13
Posted 20 March 2012 - 04:00 PM
#14
Posted 20 March 2012 - 11:29 PM
#15
Posted 21 March 2012 - 12:55 AM
#16
Posted 21 March 2012 - 03:03 AM
And they have a 10% coupon code on their website you can use at the store too.
Herve
#17
Posted 23 March 2012 - 07:19 PM
I tried pillow tops of feather and man made fillers, various memory foam toppers from 1" to 3" thick from Pennys, Bed Bath & beyond, and Walmart. Tried Gel Memory Foam mattress from Costco. None of them worked for me. Just does not pay to go cheap on over seas made memory foam. I decided that I was intending on keeping my Hawk for a long time down the road and with my bad lower back the FWC supplied cushions were just plain torture to sleep on. I did extensive research online of organic USA made Memory Foam mattresses taking in account of the negatives of Memory foam. I decided to bite the bullet and go with a 6" Tempflo RV mattress which was cut to the specs of the pull out bed of my Hawk with the extended cab. My wife and I are so glad we did, we like sleeping on it better than our bed at home. It never gets hot because it breaths and does not get hard when is cold. It does not smell like cheap foreign memory foam either. The mattress is flexible enough that we fold it at a 45 degree angle when the pull out is slid back in to access the sink. Currently I am working on setting up a strapping sytem that will secure in place when the pull out is in. It is soft enough that I have no problem lowering the top. The negative of course is the cost, $600+. I figure for 10 to 15 years or more of use, that the price is worth the comfort.
Walldiver,
I agree with you the 600 bucks is worth good sleep. I have been working shifts for the last 14 years and I have come to learn how important good sleep is. Especially on holidays! Keeping in mind I have yet to lay my hands on my new/used Hawk. Can you tell me how much the mattress compresses when you close the top?
#18
Posted 02 April 2012 - 04:27 AM
Someone had mentioned that the memory foam gets hard when cold. Any knowledge or experience with this?
Thanks~
DR
I bought a 4 inch "topper" from Costco, Queen size cut in half to make it fit. Hard as a rock in the winter until it heats up with body warmth and hot in the summer ....... but, oh so comfortable.
#19
Posted 03 April 2012 - 03:19 PM
Walldiver,
Ramblinman,
Sorry I did not respond sooner, been busy with other things. The mattress hardly compresses at all when the top is down. I do not use a sleeping bag on the mattress, I use sheets and a light bed spread with a thicker blanket on top of that. When I have the top down, I remove the heavy blanket. I have the gas lift assists installed and I have no problem with them interferring with the mattress. I'll take picture of the top down if you are interested on buying one.
#20
Posted 27 September 2012 - 02:42 AM
June & Bill
