Shot of the twist in the panel, not concerned on panel performance but flexing of the wooden roof while the truck is in motion increasing the twist.
Will probably disconnect front outboard Z bracket from panel and allow it to return to normal then shim it so its level with the front inboard .
Response from Bryan Wheat @ Alaskan
"Stephen, Looks good. The rear area can have a little sag to it on the longer campers with an A/C unit. Also the area around the A/C unit has an 1/8” luan piece that “turtle shells” the A/C area to help distribute the load on the 2X2’s. Thus the rear solar mounts are most likely resting on the 1/8” where the fronts are not. Also the center 2x2’s have 1/4” strips on them to make the vents the highest point for water run off."
Makes sense now so I will shim
Edited by BluesideUp, 12 January 2015 - 09:35 PM.
