Posted 23 January 2015 - 08:19 PM
Clever Coffee Dripper
shares
$19.00
Price MatchGift Returnable
In stock
(Quick Ship - Ships Next Business Day!)
SKU: Clever
Overview
Brand
Reviews
Questions
Aptly named the Clever, Abid's full-immersion dripper produces a clean, tasty cup that couldn't be any easier to use. To brew a cup, simply place a filter in the brewer, add ground coffee, pour water over the coffee, steep for 2-4 minutes, and then place the dripper on top of your cup. The cup's rim engages the release valve and the coffee begins to drain through the bottom of the dripper into your cup. Depending on the size selected, this brewer takes either a standard #2 or #4 filter, either of which can be selected after clicking "Add to Cart." If more filters are needed, see our listing for Melitta coffee filters .
Durable BPA-free plastic body
Includes dripper, lid, and coaster
Works best with #2 or #4 size filters
Available in 18-ounce (yields ~16 ounces) or 10-ounce (yields ~10 ounces) size
Designed for manual, immersion-style coffee brewing
Brews one cup at a time
How to brew
24-27 grams of medium- to coarse-ground coffee
400-450 milliliters of water, heated to 200-205 degrees
3:30-4:00 total brew time
*Image is a representation. Actual product may vary based on model, size, and options selected.
Abid
Abid is the brains behind the Abid Clever Dripper, a full-immersion by-the-cup coffee brewer. The Abid Clever Dripper is an easy to learn, single cup manual coffee brewer that simplifies the brewing process. To brew, you place the coffee filter and coffee into the Clever Dripper, pour the desired water volume over, let it sit for 3 to 4 minutes, and then set the dripper on top of a coffee mug to drain out. The Clever has a release mechanism on the bottom that allows the dripper to drain when placed on top of the mug. Clean up is as easy as dumping out the filter and rinsing with water. The Clever is the perfect place to start for someone who is wanting an easy to use single cup coffee brewer.
Was, 1988 Toyota custom cab 4by with 1984 fwc Fleet
Then,1995 Toyota T-100 4by with 1984 fwc Fleet
Then,1993 Toyota T-100 longbed 4by with 2002 fwc Ranger
Then, 2002 Toyota Tundra AC 4by with 2002 fwc Ranger
NOW, 2005 TOYOTA TUNDRA DOUBLE CAB 4x4 WITH 2001 FWC HAWK EXT
