That's what I put on my fwc. it drains slow but who caresMust be time for our annual valve discussion If you want can get one of these. http://www.ebay.com/...49c132c&vxp=mtr
Fresh Water Drain Leaking
#12
Posted 16 September 2014 - 06:50 PM
The fresh water valve problem was more than a minor irritation for me. Earlier this summer some of the diluted bleach solution (part of the purification process) leaked and actually etched lines in my then brand new truck. As you might guess, this did not make me happy. I put a plug in it at that time and need to replace the valve with something of better quality, as has been suggested in this thread.
2017 F150 with 2017 Hawk
#13
Posted 16 September 2014 - 06:57 PM
I did this same valve on my 2013 Hawk as it drains out the back. On my 2002 Hawk with the tank on the side like the ATC I put in an elbow where the valve was. Ran a tube to the back and put in a hose valve. I really liked having the valve to get water out side if needed, it also drained fast. The new valve is clean but it drains slow, too slow if you wanted to get water for use.
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
#15
Posted 18 September 2014 - 02:43 AM
I am working up the gumption to tear my water system completely out to gain the space. I have never used it.
I just use the 2 gal. rectangular generic purified water containers from the supermarket. The built in water system is just too much to worry about maintaining cleanly and safely. Right now the sink is just a catch-all container for odds and ends that never get put away properly.
The water jugs I buy fit under the sofa, so it keeps the C.G. low.
Edited by winks, 18 September 2014 - 02:45 AM.
#16
Posted 18 September 2014 - 04:15 AM
Appears different type valves were used, over the yrs. mine on 99 Grandby. I was told not to put a brass valve into the plastic threads of tank, can tear them up. And got tired of leaking Camco junk valves. So, I used a Pex type valve I found at Home Depot with male pipe thread on one end and push in 3/8" OD poly hose fitting on end. Keep a short section of hose in propane tank compartment near by to drain away from fender or fill bottles etc. Just stick hose in end, has one way grip, push up on collar to remove hose. Had stock valves leaking within months this one has much better valve guts no leaks for 2 yrs. now. Similar to this, at HD, but mine looks like different brand, this got one bad review:
http://www.homedepot...-3012/100203926
Camco:
http://www.rvautopar...CFVVsfgodtYEALg
Mine:
Edited by 180pilot, 18 September 2014 - 04:57 AM.
#17
Posted 18 September 2014 - 01:25 PM
I did something similar to BillHarr's set-up. Used a bronze ball-valve and a plastic 90° fitting in the bottom of the tank. The exit end of the ball-valve has a garden hose adapter screwed into it so that I can use our sink drain hose to route the water off the truck when emptying the tank. I do have some concern about it freezing in cold weather, but so far that hasn't been an issue.
Where does that road go?
#18
Posted 19 September 2014 - 04:48 AM
Oh, mine has frozen numerous times if you force it, it will break. if I need to use it, I heat some water on stove put in a spray bottle and spray it down. I find it most handy when I need to wash my hands when outside....Could put a piece of foam around it......
#19
Posted 21 August 2022 - 05:48 PM
My plastic one got stiff because it was dirty from road dust. I removed it and cleaned it by soaking brushing with an artist brush and now the valve turns better. I'm thinking about applying some silicon grease (better for plastic) but maybe it will attract more dirt?? I'm going to try a cork in the spout might keep dirt out to keep the valve turning nicely. I question some of the modifications listed here due to issues with freezing during shoulder months. I like having a valve that works well so we can fill our solar shower.
