marshfly, "why?", I was trying to creatively think of a half ton truck that was short, totally stock, level, under GVWR, under max axle load for a loaded wet camper with several 100 pounds of spare capacity. Trying to minimize the risk of post purchase rear sag.
What's the advantage of a half-ton for a pop-up?
#21
Posted 27 June 2014 - 11:53 AM
#22
Posted 27 June 2014 - 12:38 PM
That aluminum body looks promising, but it's a heck of a risk to take on a new technology. Ford tested it under heavy use, but how will it hold up over the years to street salt or in coastal areas? I wish they had paid more attention to corrosive environments. I'll be interested to see what the payload numbers look like...a legitimate 2500 lbs or so for a crew or extended cab half ton? That would be interesting. Although I'm not sure why they'd still call it a half ton, other than marketing.
2014 Ram 2500 CCSB 5.7 Hemi 4x4 - Looking for a Silver Spur Hawk/Fleet/Eagle!
#23
Posted 27 June 2014 - 02:26 PM
If you're looking for under GVWR, you'll have to either go with a very minimalist camper (next to zero options) on a very basic half ton (no crew cabs need apply) or go to a much bigger truck than a half ton. If, on the other hand, you're willing to accept the fact that thousands of trucks, up to and including 1 tons, are running around with truck campers and are over gross but probably not over individual axle ratings which is probably the more important number, then you can be a little more liberal with your camper selection.
Quite frankly, even 3/4 tons of not that long ago couldn't carry all that much on paper. My brother had a king ranch diesel crew F250 that had less than 2000# payload. Even new ones aren't much over 2000#. Maybe 2200-2400#. That won't cut it for anything other than a popup.
Again, if you're looking for a camper that's much more than a shell with a bed, you'll be looking for more than a half ton truck if you insist on being under the somewhat arbitrary GVWR. Also, if you insist on being under GVWR, you need to insist that the actual camper you are buying be weighed with scales and ignore the fairy tale weight claimed by the manufacturer. They are often so low as to be criminal.
Edited by Marshfly, 27 June 2014 - 02:30 PM.
2014 Ram 3500 Crew 4wd Cummins, 2013 Lance 855
#24
Posted 27 June 2014 - 04:43 PM
Comparing those weights is why I started this thread, actually. My planning factor is 1500 lbs for an FWC Hawk with options, water, and extra gear. Add 500-700 lbs for family depending on who comes along, and that's why I'm saying I'll be at or above capacity for most half-tons...especially since I don't want a regular cab. I'm sure most half-tons can still safely carry a bit over the sticker's GVWR, but I don't want to have to worry about how much my gear weighs, or worry about emergency braking or anything. If there's a half-ton out there that can really do that, or if there's some other half-ton advantage that I hadn't thought of, then I'd consider it. But as for now, I'm leaving very heavily towards a 3/4 ton.
Thanks for all the thoughts, everyone. Keep them coming if there's more!
#25
Posted 27 June 2014 - 06:02 PM
Thank you for your statements.
I agree a lot of the trucks you see with campers are above their GVW. weather 1/2 or 3/4 or larger.
The bigger the truck the more some want to have it carry.
I have an 02 Tundra AC loaded. I know I am over GVW I have weighed it. I try hard to not carry things we don't need. Simple the better.
I don't use the rig for serious off road camping so don't feel "unsafe" driving to my favorite spots.
Thanks for posting your thoughts.
Enjoy what you have and be safe is my feeling.
#26
Posted 01 July 2014 - 12:00 AM
As stated previously, a half ton will get better mileage and provide a softer ride.
A 3/4 ton will haul the camper a lot better. A lot.
My F350 didn't know the pop-up was there. However, the truck was a kidney buster un-loaded.
#27
Posted 08 July 2014 - 04:26 AM
My tundra hauls my Romin Chariiot just fine, though I have several suspension and horsepower mods that make it drive over logs and go to warp speed in a short period of time.
#28
Posted 10 July 2014 - 07:19 PM
#29
Posted 10 July 2014 - 09:14 PM
#30
Posted 28 July 2014 - 01:00 PM
