Air Conditioner?
#21
Posted 10 May 2008 - 07:29 PM
How are you using your Swampy? Ceiling fan on/off. Window/door open closed. etc?
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#22
Posted 20 June 2008 - 06:31 AM
#23
Posted 21 June 2008 - 03:08 AM
I would think doing the above and then turning the fan off and strategically opening windows or perhaps using the fan on low w/ the swampy might yield the best results.
Anyone else have any suggestions on how they have best found their swampy to work?
#24
Posted 25 February 2009 - 06:42 PM
Dust is the big problem at BM. The outside temp is tolerable, but the temp becomes a problem when one wants to close up tight inside the 4WC because of the dust.
Former Grandby owner
#25
Posted 25 February 2009 - 09:53 PM
#26
Posted 25 February 2009 - 11:05 PM
Patrick
2015 FWC Hawk Flatbed
#27
Posted 25 February 2009 - 11:20 PM
Lake Playa very fine silt is a very small micron size and will find it's way into everything.
Yep, two time burner here and I never got the playa dust out of my old rig before i sold it! Totally worth it though!
Sunman2003 Four Wheel Camper -Hawk
2023 All Terrain Camper - Panther 2006 Toyota Tundra Double Cab Limited 4WD
2017 Toyota Tundra Double Cab Limited 4WD
#28
Posted 25 February 2009 - 11:28 PM
Five times for me, blowing s%$t up is fun, always rent a motorhome with extra insurance. P.S. you should probably tell them you're going to Yellowstone if you go the MH route.
#29
Posted 25 February 2009 - 11:32 PM
The swamp cooler should work well in the dry Nevada desert however, the area it cools should be vented to let the moisture out. How do you do that without letting dust in? Perhaps a window screen, finer than sand yet allows water vapor to pass?
Maybe vent out one of the access panels so at least the dust doesn't have a direct shot in? I'm not familiar with the stuff...
