Gave the system a real world try camping the last few days in the Smokies and it worked great, except that the rubber clamps aren't strong enough to hold the unit under the cabinet, at least on the roads I drive. Now to rig up a strap to hold it in place so it doesn't bounce loose.
Using a pro audio adj speaker stand to raise your roof
#21
Posted 18 December 2014 - 06:28 PM
#23
Posted 18 December 2014 - 07:15 PM
Might try these Quick Fist Clamps.
http://www.quickfistclamps.com/
Cheap and sizes hold a variety of items and weights
#24
Posted 18 December 2014 - 07:32 PM
I have some quick fist clamps somewhere from a prior application, but I'll probably just use a strap. I tried looking in Townsend at the Ace hardware but couldn't find bracket I liked to mount the strap. I'm sure I can find something here around home.
#25
Posted 11 July 2020 - 05:02 PM
Ouch, hurt my back, herniated disc. Not to fear, picked up the speaker stand from B&H photo, $116 with tax. Tripod legs screw off easily, used rubber from leg on bottom, works perfectly. Made some small wood brackets that I installed with heavy duty double sided tape, has little 2" indentation in middle to keep speaker stand from squirreling around, rubber foot on floor works perfectly as is.
Gave it a crank, now I don't have to use my back to lift the thing. {joy}
Stand: https://www.bhphotov...Up_Speaker.html
Now just need the quickest clamps, my roads are often very bumpy. Cheers and Thank You to Bob, original posters and discoverers!
______________________________
2019 Hawk / Ford F250
#26
Posted 11 July 2020 - 05:27 PM
I just leave mine on the floor when traveling - its the first thing I grab when lifting the roof. It is then stored away until I am ready to drop the roof. No problem with bumpy roads.
#27
Posted 13 February 2022 - 07:05 PM
How do you feel this system would work with a 48lb raft frame on the roof with yakima racks? We have the exterior struts already on an ATC Bobcat. We don't want to remove the frame each night when travel to river trips. How secure would it be with the weight up there at night and any possible damage to the locking panels?
#28
Posted 13 February 2022 - 08:50 PM
#29
Posted 13 February 2022 - 10:54 PM
Wow! Four 80 lb struts ==> 320 lb total lifting assist minus reduction due to strut angle. Makes my 30 lb rear and 20 lb front struts seem wimpy. I do have a speaker stand for help when the arthritis kicks in.
Do you have to pull the roof down when the canoe & Maxtrac are not on the roof?
#30
Posted 14 February 2022 - 05:38 AM
Yes indeed, we need to pull the back down. The solar panel is up front, so that is always a challenge to get lifted up the first 2-3 inches.
The real trick is to use your head. By that I mean, be smart and use the fan to help both lift and drop the top. In our Puma that works way better than it did on our Hawk. I think that is because when I gutted and rebuilt this camper I made sure to seam seal and tape every opening and gap. Where I could not get easy access, I used spray foam. The camper is tight. So the fan really helps. And, I do physically use my head rather than arms to life the roof. I find it much easier to squat under the roof lift panel, touch it with my head and then just stand up.
Also tagged with one or more of these keywords: Speaker Stand
Trucks, Campers, Gear Forums →
Gear Exchange →
Adj Height Speaker Stand Tripod for SaleStarted by SB_Surf , 13 Jun 2018 four wheel camper, roof, lift and 2 more... |
