How to you secure your FWC?
Security Alarms
22 replies to this topic
#21 bfh4n
bfh4n
  • 235 posts
  • LocationLovingston, Virginia
Posted 03 January 2015 - 02:23 AM
Thanks, MarkBC for explaining Private Message and thanks, Captm, for the PM about the through bolts.
- Bernard
2014 silver Fleet front-dinette
2007 Tacoma Access Cab 4WD TRD V6 6-speed
#22 Lighthawk
Lighthawk
    Fellow Wanderer
  • 3,288 posts
  • LocationNevada City, CA
Posted 03 January 2015 - 05:48 PM
Look up tuffy lock boxes. Solid product. They did not make a model specifically for my dakota so I measured and found one that could fit with little modification.
My motto is out of sight out of mind.
I've set up a Pelican 1510 case which rides behind the drivers seat, where I've removed the rear seats of our access cab.  I lock the case to a Kryptonite cable that I've threaded through the metal body of the Tundra storage compartments.  It won't stop someone with time, but smash & grab attempts should have a tough time.   I keep it covered, and my rear windows are tinted dark.
"Out of sight, out of mine"  Is best insurance.
Another thought:  Don't flash your gear around, then walk away from your truck.  I tend to keep most gear hidden from view as a general practice.
Pro tip:  you can slip a laptop between the mattress and the dropped top.  With a neoprene sleeve, we even travel rough road with a lapper tucked up there.
06 Tundra AC TRD 4x4, 08 Hawk, Ride-Rite bags, Helweg sway bar,18" BFG AT's
2021 RAM 3500 Crew 4x4, 6.4 hemi/8 speed trans with 4.10 gears, Timber Grove bags, Falken Wildpeak 35" tires
2008 FWC Hawk with victron DC-DC charger, 130w solar, MPPT controler
http://lighthawkphoto.com
#23 camelracer
camelracer
  • 944 posts
  • LocationGoleta, Ca
Posted 04 January 2015 - 08:03 AM
I made the inside deadbolt knob removable so the bad guy can't unlock it if he breaks the window. If I'm inside the camper I can put it on and lock the door.
2002 Fiat 2500 CTD 4x4, FWC Grandby 1951 Willys CJ3A
Also tagged with one or more of these keywords: Security, Alarms
