I had noticed the following on my 2013 Fleet and retested it again today to confirm...
While my truck is running my stock Sure Power 1314A engages bridging the truck and camper batteries together. If I enable my solar system On and turn Off the truck, the 1314A remains engaged and the solar system then shares the charging of the truck and camper batteries. Not excited about that...
If the solar system is then turned Off or a significant load (ie furnace or fridge) is turned On, then the common batteries voltage drops and the 1314A finally disengages.
It appears that the 1314A does not sense the truck-side only contacts to determine when to disengage.
Have others experienced the same 1314A behavior?
Is there a smarter separator/isolator on the market?
The 1314a does only sense on the truck side, when it is opened. Once the 1314a is closed by the charge from the alternator the banks are connected and there are no more sides. The 1314a waits for the system voltage to drop below 12.8 and opens, separating the banks, keeping the main battery at 12.8, no matter how low the house battery gets. So yes I have observed this behavior and I think it is good?.
