Full build - Reconstructing a 1981 Grandby into a custom Hawk!
#261
Posted 29 May 2018 - 03:54 AM
Storage spaces were made out of what seemed like available useable space, and not sure what will go in them fully as yet. Batteries will go in the lower half of the front seat box, Lagun table mount pieces will go in the narrow storage compartment along the side of the dinette when the bottom bunk is in use.
1999 F250 crew cab SRW, 7.3 Powerstroke TD
1981 Grandby shortened to a Hawk
Build thread / https://www.wanderth...by-into-a-hawk/
#262
Posted 01 June 2018 - 09:35 PM
Ok I think I get it. I guess I should look up those lagun tables. I assumed you just left the brackets on the table. I will say that we move more than I would like round and round as we go from day to night inside. So you were probably wise to create a space. Have a tall young flexible person on standby to help. 😎
#263
Posted 11 June 2018 - 01:30 AM
Good weekend catching up some more on completing this project.
First let me catch up on some things I meant to include on the last post. On the rear seat box nearest the door, I had to insert and attach two aluminum Chanels, bolted to the side wall, to take the pressure exerted on the box when leaning back on the seat. I also created two brackets out of bed rail angle iron I had handy, to form the seat back supports. Here's a few shots of those.
Seems sometimes you have to back up a little when you find something not quite right. Had the camper off the truck for the first time since I loaded it over a year ago. And when off and I could see the underside, I noticed some slight weathering on the floor pack beneath the door where moisture catches the overhanging part of the bottom during in-climate weather. Even though I had applied a generous amount of marine enamel to the underside when building the floor pack and had the camper upside down, there was still some moisture penetration and slight cracking of the exterior of the plywood along the edge. Hard to believe, but once discovered it need to be addressed. I noticed this when I was adding some 1x4 runners underneath the camper, permanently attached, verses the 1x2 slats I had put in the pickup bed loose originally.
I applied some more paint but didn't feel the paint was going to seal up the cracks very well and they might worsen. Then I remembered what Bombsight had done to his underside floor pack, and decided I would apply truck bed liner as he did. I chose the same brand as Bombsight after reading some reviews. It's called Herculiner, and comes in a kit that includes a roller with two stiff foam roller pads, some scotch bright sanding pad, and a paint brush. The directions call for slight sanding on any glossy surfaces to scuff them up, and then applying a first light coat of the product. After allowing to dry for several hours (1-4), applying a second coat. It went on pretty much that straight forward. You have to wait until the first coat is no longer tacky to the touch, which took about 3-4 hours on a warm day for me. The formulation has small bits of rubber suspended in the solution, and it's a polyurethane base if I remember right. Plan on getting messy and throwing away a set of clothes. Theres no way to apply this stuff on the underside without it dripping down onto you while working. It doesn't come off of skin very well either, if you leave it too long. It was tedious to apply as I had to dob along all the edges of the 1x4 runners, as well as the various angles of the floor pack with the included paint brush, before using the roller to apply in between. But now it's done, I'm very pleased with the outcome.
The floor pack now has a plastic coating sealing up everything really well, and I hope keeping this pretty much maintenance free. Additionally, I now have the runners installed, and a more slide resistant surface as well. Heres a few shots of that.
While that was all drying, in-between I began working on sewing up the seat cushions, which Im happy to be tackling now. I had previously purchased a 32"x82" piece of cushion foam from Galaxy Upholstery Supply in Las Vegas. It's fairly easy to cut the foam utilizing an electric carving knife which I picked up for a few bucks at a thrift store. It works the knife pretty good, but it did the job. The cushion covers turned out pretty good. Cutting out the pieces and sewing them takes a little getting used to again when it's been a while. But I'm getting the hang of it again and they're getting easier.
#264
Posted 11 June 2018 - 05:47 PM
Nice Pokey!
Very timely for me, I'm starting to work (FInally) on my dinette. Remember back a couple years ago, I went out to the camper to measure and make plans for a dinette only to discover the flood Ultimately, the dinette was put on hold. Way past thread update time now.
Last time I worked with bed frame iron that stuff was so hard I almost gave up on it. Wonder where that steel comes from? But, it is cheap, especially since it's often laying around the scrap pile!
#265
Posted 11 June 2018 - 09:24 PM
Thanks for adding the link back to your post. I do remember your project, and it was interesting to see how you tracked down the leak and solved the problem. I trust it’s still doing fine after all the work you put into it.
Make sure to post your side dinette build when you get it started. I’d love to see what you come up with!
Poky
#266
Posted 12 June 2018 - 04:45 AM
Poky.
Great to see the continued progress. everything is looking great. You have fantastic attention to detail!
My youtube channel about my Four Wheel Camper - https://www.youtube.com/c/timmorrissey
All about my camper - https://www.tgmorrissey.com/camper
Item I used in my build- http://bit.ly/TGMorrisseyParts
#267
Posted 25 June 2018 - 12:05 AM
Tim, Thanks for your comments. Ive still been enjoying your video postings too.
Well the surge continues. I've been busy over the last week or so with several projects as I near completion. In my last posting, I had begun sewing up the seat cushions, and now they are complete, for a total of eleven between the upper bunk, and the lower dinette/ bunk. I had purchased a large roll of fabric that I figured should have enough, and then some, to complete the arrangement. To my surprise, and delight, it ended up I had only just enough for the last cushion, and wouldn't have had enough for even one more. Good thing I didn't make any serious mess ups. So I truly lucked out. I used naugahyde on the bottom of the upper bunk main cushion, which in hind sight, spared me from running out.
Anyhow, it sure is nice to finally be to this point. I'm pleased with the way they turned out, all in all, and it gives the camper a finished look and feel. Here's a look at how they turned out.
Finally, I installed the water system, including the water tank, the electric water pump and switch, and the sink and faucet. I still have to hook up the drain hose and valve to exterior, and that's underway.
#268
Posted 25 June 2018 - 01:20 AM
Looking good there sir. That lower bunk has a lot of sleeping area for sure. Have fun camping.
Russ
#269
Posted 18 July 2018 - 01:21 AM
A few shots of Capitol Reef's geologic formations.
#270
Posted 18 July 2018 - 02:24 AM
Looks awesome Poky! Gald to see you out and about in the camper!
