A 79 C/O Alaskan with some improvements.
#11
Posted 27 September 2016 - 06:36 AM
#12
Posted 27 September 2016 - 09:14 PM
So like I said I removed the full size water tank and replaced it with a half size I ordered off amazon. I used a mix of pex and rubber hose to run lines. I had to replace the pump sink faucet. They are cheep but also built cheap. Works good. I replaced both hoock ups on the outside. Hook the water up to one and when it's full it blasts out the other. Tank is sufficient for the camping we do. Lasts 3-4 days without being to carefull. I run a small hose off the sink drain and just stick it in a 4l water jug for grey water.
Edited by ShackBait, 03 October 2016 - 05:19 PM.
#14
Posted 27 September 2016 - 09:19 PM
I installed a 12volt fan under the top cabinet. Tied into the wiring for the light installed under the same cabinet.
Replaced the old 12v outside light with a new LED one. It's bright but the light it gives off is not very pleasant.
Edited by ShackBait, 03 October 2016 - 05:20 PM.
#17
Posted 27 September 2016 - 09:28 PM
#18
Posted 27 September 2016 - 09:30 PM
The Perrelli webbing (I think that's what it is called) is kind of rough on the outside. I ordered a roll but only replaced the door section. Will get to the rest later. It is expensive stuff.
Edited by ShackBait, 03 October 2016 - 05:22 PM.
#19
Posted 27 September 2016 - 09:33 PM
Installed a digital thermometer in the camper. It reads outside and inside temp. Found a consistent 5' Celsius spread during our trips when we were in the camper. Worth the $20 purchase price.
Edited by ShackBait, 03 October 2016 - 05:23 PM.
#20
Posted 27 September 2016 - 09:35 PM
Also installed a co alarm as well as a smoke detector. In the same picture you can see I screwed pipe insulation along the wood edge leading into the bunk. It was just bare wood and the boy kept hitting his head on it.
1 user(s) are reading this topic
