nice shot how many watts?
300 of renogy 100 watt panels
victron 100/15
victron battery monitor.
11 amps is around what i get in decent sun
Posted 16 October 2017 - 10:09 AM
victron 100/15
Posted 16 October 2017 - 05:52 PM
That's awesome. I just have a single 265W panel made by Canadian Solar. It maxes out my Victron 75/15 on any kind of decent sunshine. ;-)
broverlanding,
I'm curious about roof weight. Are you using flex panels or solid panels?
Those panels in the picture look like monocrystalline panels which weigh about 17 pounds each without the connecting cables and mounts. I'm guessing around 60 - 70 pounds total with cables and mounts.
Can you lift the roof unaided or do you need to use a speaker stand or equivalent?
I have 2 monocrystalline panels on the roof of my Keystone and I think one more panel would make it too hard to lift without aid, particularly in the front (I do have the gas strut lifter helpers on the front -inside - but not on the back). My panels are mounted in the middle and in the back (similar in location to the two panels in the middle and back on your roof).
I am considering using a flex panel to add another 100 watts and placing it in the front location but that will still add close to 10 pounds with cables and mounting.
BTW: I am very happy with my Victron charge controller and battery monitor. They work great and the bluetoth app is very convenient to use.
Regards,
Craig
Edited by ckent323, 16 October 2017 - 05:56 PM.
Posted 17 October 2017 - 10:20 AM
broverlanding,
Regards,
Craig
3 solid panels from renogy. The front is kinda harder, but its not all that bad. I dont struggle or anything.
Posted 17 October 2017 - 12:05 PM
Grant,
loved your Flickr stuff
2018 Ford F-250. Customized Bundutec Sable
Posted 17 October 2017 - 03:32 PM
Edited by ckent323, 23 August 2019 - 02:07 AM.
Posted 17 October 2017 - 10:34 PM
The Victron MPPT limits the battery current to 15A but you shouldn't use panels with an output over 20A according to the spec sheet.
2016 Fleet Flatbed
2016 Toyota Tacoma
Posted 17 October 2017 - 10:39 PM
correct. I did contact them and they said this setup was fine. they said if i did another panel i should step up to be safe if its a full time use.
with the 100/30 i can also add a spare panel at the rear for a flexible panel or something.
Posted 18 October 2017 - 01:33 AM
Yep, mine limits the current to 15A, but that isn't an issue often. If doing my system over again, i would also opt for the 100/30.
Posted 06 August 2020 - 05:57 PM
I've got more build experience and solar thoughts over on my build thread:
And a recent trip up to a lake outside of Prince George, BC. gave us another data point: We were camped in partial shade. The 330W rooftop panel could NOT keep up with our demand (which includes a 1800W inverter cooktop) can can easily keep up when we are moving about and parked at sunny trailheads.
