Turnbuckle Question
#71
Posted 01 October 2017 - 04:17 PM
So now that we have a FWC fleet on the way, I have been wondering if there would be room to build some kind of short assembly for inside the bed mounts using their Derringer model.
I guess this answers my question
#72
Posted 09 October 2017 - 08:28 PM
#73
Posted 24 October 2017 - 01:10 PM
Hi, doing my bit on learning the ins and outs of FWC since I'm in the market for a Swift/Finch camper. I was wondering if anybody has used the Rachet strap system on the FWC like Phoenix Campers.
#74
Posted 24 October 2017 - 05:21 PM
i fixed it with sourcing stainless steel ones. The crappy ones supplied were garbage and after 2 months have pretty much become useless due to corrosion.
i think we will be selling them around 24 bucks a piece
http://www.qmh-inc.c...=20160104000005
Edited by broverlanding_tacoma, 24 October 2017 - 05:22 PM.
Dometic - Tern Overland - Flarespace - Blue Ridge Overland Gear - WARN - Bedslide
#75
Posted 13 March 2023 - 10:57 PM
Vic, I have been trying to purchase the newer camper side eyebolts (upgraded to latest FWC style) but could not find a supplier. So I am about to get four made for me. I guessed the dimensions as 1/4" Stainless steel angle- 1 1/2" x 2" x 6". Is that about correct?
Thanks, Al
#76
Posted 14 March 2023 - 06:16 PM
Thanks, Al
I had mine shipped from FWC. Your dimensions sound about right. It's the upper 3"x6" plate that is more critical. What camper are you modifying? Are you in Calgary?
#77
Posted 15 March 2023 - 12:25 AM
I am in Jasper and it's a 2005 Hawk. I wasn't sure if I would be able to get the new brackets or not but turns out a machine shop in Hinton was happy to make them for me. I had them put a 75deg angle on them instead of 90 so that the pull is directly towards the forged eyebolts in the truck bed. I will try to attach a couple pictures of them. Since I didn't know if I would be able to get the brackets I went ahead with 3.5"x8"x 1/4" plates both inside and outside on the camper, Then used three grade 8 bolts at each corner with the original camper side eye nut. Now that I have the brackets I will be able to just bolt them in. I guess it might be a bit over built but maybe the turnbuckle will now be the weak point?
#78
Posted 15 March 2023 - 04:40 AM
Looks good. Yes, the turnbuckles... I like my FasGun Derringers, but others here are using a variety of techniques to secure them... wingnuts, safety wire, etc.
#79
Posted 18 March 2023 - 08:24 PM
With the big turn-buckles on our old camper I used safety wire and it worked very well. With the new(er) camper I'm just using the jam nuts supplied on the marine safety line turn-buckles (both LH & RH nuts) and I've not seen these loosen. They are outside of the bed where they're easy to get at.
Where does that road go?
#80
Posted 19 March 2023 - 03:01 AM
Jam nuts only here....have not loosened.....lots of off road pounding...'16 Hawk, plates intact....
