used hawks on many a sporty car. Awesome
Tundra Brakes
#11
Posted 06 December 2017 - 10:50 PM
#12
Posted 08 December 2017 - 12:52 AM
I second ntsqd -drilled rotors are left over from old pad compounds and are about as useful these days as the hood scoop on my truck that is totally enclosed. They also reduce the surface area for the break pads to contact the rotor and cause uneven heating and cooling of the rotor which is where cracks can come from in some rotors. All of the big brake kit upgrades get added braking by increasing the brake pad size and number of pistons to get added contact with the rotor not less.
Slots not only clean off some dust and dirt from the rotors faster but they also wipe the rotor of water more quickly than non-slotted rotors which speeds up braking after going through water. It is one of the reasons my neighbor, the race mechanic, says they are used in racing at every level. I like EBC slotted rotors with green pads. The pads do wear a little faster but they definitely improved my braking. But I have a Tacoma not a Tundra.
#13
Posted 15 December 2017 - 05:24 AM
Ive built (and even raced) about a Dozen various Toyotas,
First thing ive always done was upgrade the crappy brakes,
We have put DBA (from Australia) drilled and slotted on all of them and with over 100k of offroad miles, not a single issue ever!
The fronts are currently on backorder for my 2014 Tundra, but the rears are already on there and just with the rears the difference was notable.
When you hear folks talking about they might crack, that is misleading....
Some of the best most expensive supercars in the world come with drilled and slotted from the factory!
It all depends on the quality.
If you buy $50 no name drilled and slotted rotors from pep boys, yes, they will most likely crack.
If you buy a nice quality set of DBAs or Terrain Tamers, they will probably outlast your truck!
I will be putting DBAs on the front of my truck, the day they are available off of backorder!
My ,02
So what pads do you normally use with the DBA rotors? I saw rotors at Summit for $171 but no pads.
I found long ago it's best to match the pads and rotors when you can. They were usually developed together.
#14
Posted 15 December 2017 - 06:19 AM
I’ve tried about half dozen pads and I’ve been most happy with Hawk LTS pads.
Follow My Shenanigans: instagram.com/campermccampface
#15
Posted 15 December 2017 - 05:57 PM
Thanks! We've got 2 cars in the family right now with Hawk HPS and their rotors on them. Very nice.
Edited by Squatch, 15 December 2017 - 05:58 PM.
#16
Posted 30 December 2017 - 05:22 PM
Running Stage 4 EBC Slotted/Dimpled rotors with the greenstuff pads, so far much better than stock especially in the torrential PNW rain.
#17
Posted 31 December 2017 - 03:14 AM
Edited by dharte, 31 December 2017 - 03:15 AM.
#18
Posted 31 December 2017 - 04:49 AM
#19
Posted 01 January 2018 - 12:17 PM
Any brake shop in PNW, preferably in Portland area, good for upgrading Tundra brakes?
I would think most any independent repair shop that services these trucks or 4x4 place would be happy to help you out. Upgrading these trucks is mainly just changing pads and rotors.
#20
Posted 01 January 2018 - 10:09 PM
what year truck Paul? On some you can swap in bigger rotors and calipers.
