Insulating the floor of your camper
17 replies to this topic
#11 Vic
Vic
  • 350 posts
  • Locationcamping somewhere in the Sierra Nevada range
Posted 07 December 2019 - 02:50 PM
What a great idea - thanks for the tip and its on my project to-do list for the next winter trip!  Thanks!
"I took the road less traveled.  Now I don't know where I am"
2014 Dodge Ram 3500 diesel & Hallmark Everest.  (Former Rig - 99 Ram 2500/ 2000 Sunlite Eagle pop-up)
#12 DanoT
DanoT
  • 278 posts
  • LocationSun Peaks, B.C.
Posted 11 December 2019 - 07:41 PM
Eddie, great idea!
Our camper is sitting on the jacks, so a good time to add the rigid foam.
I stumbled upon this concept and it has worked great for us.
This sleeping bag pad from WalMart cut to fit.  We camped on the Alvord (OR) in a blizzard.  The inside of the camper was nice and toasty;  we could walk on the pad bare footed, that warm and comfortable.  I lifted the pad and the camper floor had to be near freezing temp.
Bill
I do a lot of winter camping and I went to a dollar store and bought a couple of $3 30"x20" kitchen mats made out of the same stuff as 1/4" sleeping mats. I put a 30"x20" drainage mat on top so any snow that melts or debris that is tracked in ends uo on the dollar store mat and the drainage mat remains dry. Easy cleaning: Lift off the drainage mat and drag the dirty kitchen mat outside.
Edited by DanoT, 11 December 2019 - 07:43 PM.
1991 Dodge CTD, owned since new. 2011 Coyote RV Phoenix pop-up camper, custom made for the Canadian winter.
#13 rubberlegs
rubberlegs
    curmudgeon
  • 564 posts
  • LocationEverett, WA
Posted 12 December 2019 - 08:10 AM
We use two layers of carpets.
Tacoma/Fleet 2018.
#14 Sleddog
Sleddog
  • 182 posts
  • LocationIdaho
Posted 15 December 2019 - 02:52 PM
I insulated the floor of my camper, but chose to put the foam inside and covered it with a piece of 1/4 inch underlayment and new flooring, only lost about an inch and a half of head room. It helps a lot keeping cold from seeping up and the floor is now comfortable to the touch with bare feet.
#15 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,968 posts
  • LocationCalgary, Alberta
Posted 15 December 2019 - 08:46 PM
how thick is that foam?  R value?
#16 Sleddog
Sleddog
  • 182 posts
  • LocationIdaho
Posted 15 December 2019 - 10:57 PM
I used 1 inch blue board with an R5 rating, it is available faced with an R10 rating if you think you need more. The 3/4 plywood underneath plus the 1/4 inch underlayment and vinyl flooring brings it up to about an R6.5 rating overall. Even at R6.5, we noticed a huge difference in the temp of the floor and are happy with the results.
Edited by Sleddog, 15 December 2019 - 11:00 PM.
#17 rubberlegs
rubberlegs
    curmudgeon
  • 564 posts
Posted 16 December 2019 - 06:00 AM
Sleddog, did you cover the top plywood with vinyl or carpet? It sounds good that it's comfortable with bare feet.
Tacoma/Fleet 2018.
#18 Sleddog
Sleddog
  • 182 posts
  • LocationIdaho
Posted 16 December 2019 - 12:02 PM
I used vinyl flooring, solid sheet, folded up at the corners bathtub style. Might get a door mat for wiping feet, but no carpet, didn't want anything that might soak up water. I didn't use any sort of glue or fasteners,a few screws in the trim holds everything in place, so super easy to change flooring or add more insulation if desired.
Edited by Sleddog, 16 December 2019 - 12:06 PM.
