Time to make some more room...... 3 Person to 2 Person seat conversion coming up!
Up till this point we've used the factory 3 person bench seat up front for out son to travel in, while it works it's way bigger that we need it to be and makes it difficult to move from the rear of the van up to the front seats as you have to step down into the slider door well to pass the seat. The time has come to modify the seat from a 3 person to a 2 person and give us some more living space in the van.
Disclaimer....The seats integrity is vital to the safety of it's passenger. Below is the procedure I used to modify our seat and that I was comfortable with. If you choose to modify your own seat please use your own judgment and do so at your own risk.
This post will be picture heavy.....
Supplies used:
Note: The links below are my Amazon Affiliate links, I make a small portion each time someone purchases from Amazon using one of my links, at no extra cost to the buyer. I only provide links to items that I personally like and use myself. i use the money to put back into my builds and support making videos/posts. If you prefer not to use my links you can search for the same items directly off Amazon. Thank you for the support!
Surface Conditioning disk (Paint Remover) - Amazon Link: CLICK HERE
Electric Knife (Used to cut foam) - Amazon Link: CLICK HERE
Gorilla Heavy Duty Spray Adhesive - Amazon Link: CLICK HERE
Upholstery Thread - Amazon Link: CLICK HERE
100 Sewing Needles - Amazon Link: CLICK HERE
Optical Center Punch (Not a must...but a very cool tool): Amazon Link: CLICK HERE
Here's the 3 seat bench just removed from the van.
Remove the 7 screws that hold the rear plastic cover onto the seat.
The sides and bottom edges of the seat covers snap into place on the round tubing that runs around the perimeter of the seat. To loosen the cover just grab the plastic clips and pop them off the tubing.
The upper portion of the seat cover attaches to the back of the seat by a thin piece of plastic that's folded over and slipped into a metal channel. Just grab this piece and pull it out of the metal groove.
Next up remove the left side seat belt attachment point. Pry off the plastic cover and remove the bolt, spacer and plastic washers.
Now remove the seat belt latch on the right side.
A quick wrap with a little electrical tape is a great way to keep track of your parts.
Now you need to remove the head rest guides. Remove the headrests and set them to the side.
Use a thin piece of wood and a hammer to pop the plastic guides out from the bottom. Place the stick on the bottom of the guide up inside the seat and hit the stick with the hammer, the guide will pop right out.
Continued below.....
Edited by Hodakaguy, 09 February 2021 - 12:37 PM.
