Rig Build with FWC Hawk
73 replies to this topic
#61 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 24 March 2023 - 07:33 PM
Those seem cheap enough.
On my Hawk flatbed the table is in the rear and if table is too high it could swing around and shatter the rear window if it would hit to hard on a ruff road.  I guess it could happen on a front table model also.  There were pictures that someone posted that they broke their front window.
Mine also would shimmy down so I went ultra cheap and had some leftover 2" electrical conduit.  Cut to length and set the table where we enjoy the height.  The writeup and pictures were here somewhere  but could not find it.  Images attached.
Thats a good idea too. I thought for $16 it was worth it to not have to constantly readjust the table as we'll likely always leave it up and at its highest position.
  • 1
James
2016 Four Wheel Camper Hawk
2012 Ford F-250
My Build Thread
#62 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 27 March 2023 - 09:44 PM
I am hooking up my truck running lights to the camper and know the green wire coming from the camper is for those lights.
I connected a 10 or 12 gauge wire to the FWC wire which is an 8 I believe and ran that to my running light connection. Any reason why I would need to pull that cable and run something thicker to just run the running lights?
James
2012 Ford F-250
My Build Thread
#63 Jon R
Jon R
  • 763 posts
  • LocationWashington State
Posted 27 March 2023 - 10:37 PM
If your 2016 camper has LED running lights then the total current for all the lights is maybe an amp. If you have incandescent bulbs you may be at 10-15 amps. Either way 12 awg is sufficient. I ran 16 awg for my LED running lights.
Jon R
2021 GMC 3500HD CC LB SRW Gas
#64 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 28 March 2023 - 01:12 AM
Thanks! I figured anything bigger would be overkill, but just wanted to be sure and ask you legends here!
James
2012 Ford F-250
My Build Thread
#65 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 29 March 2023 - 06:56 PM
I followed the write-up here to install an awning I had from one of my previous overland builds onto my Hawk. Its a small awning but enough for two of us to sit under to hide from the sun sometimes!
Its mounted over one of the passive vents to my fridge but I am not concerned about that. These isotherms do not make that much heat and the entire vent is not blocked. You can see the lower vent/access panel is still clear as well. The interior protrusions are behind the passenger side seat and in the cabinet of the "bathroom".
I used the same hardware that the mentioned-thread suggests except a bit longer and used thread protectors on the interior to ensure no scratching anyone or anything.
James
2012 Ford F-250
My Build Thread
#66 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 05 April 2023 - 11:33 AM
I can't get my running lights to power on my camper. I feel like I am missing a piece of the puzzle.
Am I correct in my understanding that all I need to do is connect the green wire coming from the camper to a powered line that runs my truck's running lights? Why is the gauge so big for just a simple circuit of a few LED lights?
Any help is appreciated!
James
2012 Ford F-250
My Build Thread
#67 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 9,830 posts
  • LocationNortheast Oregon
Posted 05 April 2023 - 01:37 PM
Did you wire the 7 pin male directly to the camper wiring?
If so, have you put a meter to the back of the plug to ensure you’re getting 12VDC when the truck lights are on?  If not, you’re either on the wrong pin, or the truck side is the problem.
If you do have power there, you’ll need to chase/meter the camper wiring.  Does it go to a fuse block, and is there power on both sides of the block?  If there is you may have an open circuit or high impedance somewhere down stream.   Bad light circuit ground is a possibility.  I suspect they use the frame as ground, but not certain of that.
You might also jump from the camper battery to the light circuit to see if you have lights.
Hope that helps, good luck.
Real Dogs Have Beards - Fear the Beard
Tu Ne Cede Malis
#68 Jon R
Jon R
  • 763 posts
Posted 05 April 2023 - 02:07 PM
My 2021 Grandby has the light grounds run with wire to the negative bus bar near the ACR. They were not tied to the frame.
Jon R
#69 jclifb
jclifb
  • 56 posts
  • LocationAlabama
Posted 05 April 2023 - 07:44 PM
I am going to run a wire directly to battery to ensure that the lights work on the camper. Thanks for the idea to test. It could be my 7-pin outlet not powering on because there is nothing hooked up to it technically.
Does the black wire from the camper wiring need to be grounded regardless if the white wire is wired up or not? I guess, does the black ground both the battery charging (white) wire and the running light (green) wire?
James
2012 Ford F-250
My Build Thread
#70 PaulT
PaulT
    Need gumbo
  • 2,533 posts
  • LocationHillsboro, Oregon
Posted 05 April 2023 - 07:58 PM
Because the marker lights are powered by the truck's 12 volts, there must be an electrical return path to the truck's 12 volt ground. If there is conductivity between the camper ground and truck ground, you are good. If not, you will need to provide the path yourself. A DMM (Digital MultiMeter) is your best friend here.
