Ok, forgive my ignorance....
Where does one find wheel studs and are they different for different trucks? Lug nuts are probably easy. Is there a standard size for the studs/bolts for the lug nuts or are they all different. Seems so simple but could be so complex.
dave
They make about 1000 different wheel studs and about 10 different lug nuts. You can get any stud you need at your local auto parts store. OR just buy bolts that have the same thread size/count as your wheel studs and use the lug nuts on them.
Say for example you have a new'ish F150 you'd need 14mm studs - so any 14mm stud or fine thread bolt would do the job.
