Its a rigid foam board with some painted plywood veener on the bottom with the edges wrapped in aluminum trim with some silicon sealant. The trim is fastened to the edge under the cabover.
Perfect. Thanks.
Posted 01 January 2012 - 10:44 PM
Posted 04 January 2012 - 04:40 AM
I put a Bobcat Shell model on a 2008 2.7 liter 4 cyl, 5 speed manual, toyota tacoma access cab, thats the one with the reverse rear doors. I had the toyota dealer add the 4 leaf TSB spring pack to the rear axle. Then I drove around the western United States, Canada, and Alaska for one year. I liked the way the truck handled when the camper was on the "light" side, but when I added more weight i would definently notice a difference. It was slow going through mountain passes about 35 to 45mph depending on the grade. It was slow going against a headwind. It was difficult to start the truck moving in first gear especially when starting on a hill. Getting on the freeway on-ramps and getting the truck up to freeway speed was also a challenge that would make me nervous, especially in California.
I think that my average highway speed was 45 to 50 MPH. I could get it to do 60 or 65 MPH but I could tell that the engine was working hard for it and my gas mileage would drop. It was better to keep it around 50 to 55MPH. i think i was getting around 20 to 21MPG at these speeds.
Driving around town in this setup was no problem.It goes good in 2nd and 3rd gear, its a small pickup with a great turning radius. Probably the biggest issue was starting out in first gear on a steep hill.
Overall I think that the 2.7 liter was just slightly underpowered for the Bobcat in most situations, of course there were times when I had a strong tailwind and was loving it. It seemed like the engine was working too hard most of the time.
I have switched to a Toyota Tacoma with the 4.0 liter V6 with the same Bobcat Camper and love the extra power, I dont have any of the previously mentioned issues now. I also upgraded the suspension front and rear and it handles great, I like the size of the tacoma and i think its a good match to the Bobcat. I can always turn around and find a parking space no matter how small.
Posted 05 January 2012 - 08:19 PM
Thanks for the reply. For now I have to keep my 97 Tacoma with the 2.4 four and automatic. Most of the time the shell would be empty and the truck is used as a daily driver. My main concern is how the truck would handle the empty shell. I can see a full camper being to much for a smaller truck but I was hoping a basic shell would be manageable. From reading the posts it seems even the shell campers are too much for the smaller trucks. I guess a small towable popup camper is the way to go.
Posted 03 November 2012 - 04:34 AM
Posted 03 November 2012 - 04:35 AM
Posted 09 November 2012 - 11:28 PM
Posted 09 November 2012 - 11:52 PM
From Baja to the Arctic and all places between!
www.generubinaudio.com
Dodge 4x4 2500 Cummins, 6 spd manual, ATC Ocelot Shell. Tesla Model S, 85KWH, 2018 Tesla Model 3 (3 of them!!)
Posted 11 June 2013 - 09:49 PM
I had a 2012 - 900 pound (dry) FWC Eagle shell on a 99 Tacoma X-cab, 4WD, 4 cyl, 5-speed. Truck weight without the camper and tailgate - 3600 pounds. Performance on the flat to 65mph OK though most of driving is in 4th gear. Uphill I was in third at 50 mph (witrh my emergency flashers on) to avoid getting run over.
In January I sold it and moved into a 2013 Tacoma 4WD V6 Access cab. The empty weight of the truck without camper and with tailgate, half tank of fuel, no driver - 4200 pounds - 600 pounds heavier than the '99.
Both trucks had a rear suspension upgrade (new springs to support 1500 pounds ) - the '99 to 5 leafs and the 2013 to 4. Both sit level loaded for a week of camping in the desert outback (see pics). Loaded Weight : '99 -5500 pounds (300 over max GVWR) , 2013 - 5700 pounds (200 over max GVWR), Both trucks have/had "E" rated tires.
Before I bought the FWC I had a "Flip-Pac" on the '99. It weighed 425 pounds. The 4 cyl had no problem keeping up with traffic unless I had a 25 mph headwind. Then I would be at 50mph.
Conclusion:
Both these trucks are 4WD so they both weigh about 600 pounds more that 2WD (transfer case, front axel). I had/have the "shell" bolted down permanently to both trucks.
So If you are going to store your Bobcat off the truck most of the time you could "live" with the limited performance. If you are leaving it on full time buy a V6. The V^ milege is better than the 4 cyl by 3mpg.
-Jim
Posted 11 June 2013 - 11:32 PM
We've got a modified Bobcat shell on our 2011 Tacoma. Plenty of power and braking capacity. When we are loaded, the truck is at the GVWR. The suspension leaves a bit to be desired although we travel around without problems. I am considering a new spring pack and better shocks.
Posted 25 May 2017 - 06:05 AM
what about regearing the 4 banger? along with the other mods.
Edited by izzy1554, 25 May 2017 - 06:05 AM.
