Battery Not Charging
#21
Posted 14 August 2012 - 04:15 AM
I suspect that the battery is not charging because earlier this summer the house battery drained to a point where the light dimmed. It did not recharge as the truck was running. I did not have a volt meter at hand to check levels.
Also when I get a reading off the camper batt (13.22) and turn the truck off the reading stays the same. It does not do this at other points in the system.
Make sense?
I will check to ensure I do not have the separator wired backwards tomorrow night.
#22
Posted 14 August 2012 - 04:47 AM
Now if the truck side of the separator is above 14 when the truck is on and the camper battery is still closer to 13 then the separator is not closing, or it is wired wrong.
If I was there in person, I would trace the voltage on both sides of the separator truck off, measuring voltages as you have done but also noting wire colors and polarity, making a schematic drawing and noting the colors and voltages, then run the truck and remeasure the voltages. I would look for any other wires on any of the terminals and ensure I knew what they lead to, such as fuses, solar chargers, loads. Seeing your 27V and the 0.5 volt difference I mentioned is hard to address without more information like the above things (colors, tracing, loads, chargers, etc).
I would also verify the separator contacts are closing when the starter battery voltage crosses the setpoint, and opens when it falls (truck turned off).
2016 F-150 FX4 XLT SCab | Ingot Silver | 6.5' | 3.5EB | 3.55 w/rear locker | Tow | IBC | 7050# GVWR | 1945# Payload | 36Gal | BFG A/T KO2 LT275/70R18E | Timbrens
2022 FWC Hawk Silver Spur | Front Dinette | Cassette Toilet | Cooktop | Hot Water | Outside shower | CR850 fridge | 160W rooftop solar panel | 15A MPPT controller | Dual 90AH AGM batteries | Yakima Rack | 2 Maxxair fans | Furnace | Fiama side awning | Mechanical Jacks
#23
Posted 15 August 2012 - 02:33 AM
Anyway I will try to switch the polarities and post the results.
#24
Posted 15 August 2012 - 05:02 AM
Having a 7 pin RV connector is not unusual, especially if the truck it went on once had a full size camper. I used a 7 pin also. Allows the use of a commonly available connector and has room for marker light and other wires, compatible with rear bumper wiring also. There are certainly other connector options.
#25
Posted 15 August 2012 - 04:26 PM
The drop at the separator make me wonder if the new device is solid state or if they have a diode in circuit to protect against polarity mistakes.
The voltage on the camper side of the separator indicates that the separator is closing.
The drop from the separator is huge - either the wire gauge is way too small (and there will be fire), something else is in circuit (like another diode or ???), or there is no continuity from the separator to the battery.
I think 13.2 is a pretty common float voltage so it seems like there is a charger in the mix to me too. Does your system use a DC-DC charger? The wires from the separator go to a solar charger or something? If so, perhaps that device is stuck in float.
#26
Posted 15 August 2012 - 10:57 PM
Thanks Frank
#27
Posted 16 August 2012 - 01:16 AM
Key point: The camper was sold by the distributor in NC. It sounds as though this distributor does or used to deal with Lance Campers. They also, for some reason, wire in a 7 hole (not blade) wiring harness. This is something that I have yet to find or see in my neck of the woods. For what ever reason they re-wire their campers with this 7 hole harness including the FWC.
Lance: Uses the black wire as the hot wire.
FWC: Uses the white wire as the hot wire
Long story short , whom ever wired the camper at the distributor, wired as a Lance and used the Black as the positive.
The wires were crossed at the truck side of the separator.
I just checked and am getting 14.4 on the meter at the Camper Battery while the truck is running ... is it fair to say that this is adequately charging the battery?
#28
Posted 16 August 2012 - 02:28 AM
You're getting decent voltage back there now so the amount of "charging" you'll be able to do will depend on how discharged your battery is and wire gauge (more amps drop the voltage, etc.) but you're back at the normal baseline it seems. See if you like the ability to replenish the battery over your future travels.
#29
Posted 16 August 2012 - 02:33 AM
Hell ya!
I am using the new and improved sure power 1314 - However while re-assembling the cabinet I noted that the Separator was very warm to touch ... almost too hot to touch. Is this normal?
#30
Posted 16 August 2012 - 03:27 AM
Hell ya!
If the truck is off and it stays very warm or hot then something seems worng to me. If it is hot only while the truck is running, then that is due to the coil being energized and it will get very warm. How warm is too warm though, probably best left for the manufacturer to advise on. But if I cannot hold a finger on the unit for a minute or so withoiut fear of getting burned I would be concerned.
