This old Granby build
#31
Posted 13 July 2015 - 10:27 AM
#32
Posted 13 July 2015 - 10:39 AM
#33
Posted 15 July 2015 - 12:30 AM
Those lift bars look good! I've never seen that before. I can't see those rotting out anytime soon, especially if aluminum conduit was used, I like it. I too have an old grandby that needs some work, one of the previous owners did a botch job on the canvas and the front lift panel, functional but shaky at best. I can see myself doing something very similar to your build in the near future. I hope you get your frame issues sorted out.
92' Grandby, 93' f350 7.3L CCLB
#34
Posted 15 July 2015 - 02:13 AM
Creative solution to your problem. Good work! I'm wondering if, since you no longer have the spring tension and the diagonal bracing provided by the original panels, the roof is vulnerable to collapse in high wind loads. You might test it by pushing on the raised roof from different directions. Adding the spring-loaded lifting struts would help that problem somewhat. You could also add a pin or clamp where the conduit pieces overlap so they can't separate once the roof is up. I've often thought the lifting panel design could be rethought once the lifting struts are added, which most everyone is doing these days. Thanks for posting your project- helps us all learn from new ideas.
#35
Posted 15 July 2015 - 08:27 PM
#36
Posted 15 July 2015 - 08:42 PM
WV: As far as the roof helper lifty thingys goes, there is a long thread on here and part numbers and sources are listed. I used the offset brackets and 30lb, 36" cylinders. BTW, I took out the FWC lift panes all together and rely solely on the cylinders to lift the roof. I think with the cylinders and your lift panels, you would be fine. YMMV.
2011 Dodge - Cummins
Ancient FWC Grandby, coming back to life!
#37
Posted 15 July 2015 - 09:19 PM
<snip>
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#38
Posted 16 July 2015 - 08:45 PM
#39
Posted 11 August 2015 - 05:25 PM
Any update on the lift panels/tubes? Also, I put my struts on the sides just in case I wanted to put an awning on the back, over the door.
#40
Posted 12 August 2015 - 04:00 AM
What he asked. I've almost convinced myself to overhaul my Grandby and want/need to do something to my lift panels. I'm convinced some of my canvas wear came from it pinching between the lift panels when popped down. I'm wanting to consider your approach.
Old, bum around in Ford and an even older FWC Grandby
New Mantra: "Everyday camping is just making up for lost time"
