Fantastic Fan variable speed control
#31
Posted 23 August 2015 - 09:47 PM
I'm just looking for a basic fan and don't need a lot of extras. I do like the variable speed and low energy use the controller discussed above gives you. I also thought the reversing mode would be good, but I'm not sure how much I would actually use it.
#32
Posted 23 August 2015 - 10:09 PM
Thanks Paul, I appreciate the information.
If you have some skill with the electrical you can save a lot of $$$. Buy the simple non reversible fan, model 1200. Get a DC controller with a reverse switch on Ebay and install.
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
#33
Posted 30 August 2015 - 08:09 PM
I've been doing a bit of research. Since I have the factory installed basic fantastic vent unit already mounted in my camper, I'm looking into buying a used motor, fan blade and "wishbone" bracket assembly on ebay and one of the DC motor controllers with reversing switch you mentioned for my fan setup.
I have two more questions I'm hoping you can answer.
Will the newer style (low profile) motor fit under my vents' flat top cover?
I read earlier about others having to use PWMs with a frequency above 20Khz to eliminate an audible buzz. The only PWM controller frequencies (that come with the reversing switch) I found are 500hz, 15Khz, and 16Khz. Are any of these acceptable or will I likely end up with a buzz?
Edited by EDR, 30 August 2015 - 08:17 PM.
#34
Posted 30 August 2015 - 10:34 PM
Thanks Bill!
My fan has a flat cover, see image. Not sure if you will hear 16Khz. I did find an online tone Generator. Give it a try and see what you can hear. they do recommend head phones.
#35
Posted 20 September 2015 - 06:46 PM
I purchased a newer style used motor, fan and bracket off of eBay for ~ $40 and the motor controller with reversing switch for $8.
The highest PWM frequency I could find in an all-in-one assembly was 16K Hz, but the audio test link Bill shared showed that it was still well above my ability to hear.
FWC pre-wired the Hawk for a fan, so the wiring was actually pretty straight forward.
My only issue was the motor bracket. For whatever reason it was too big to fit into the slots on my 2007 Hawk's Fantastic vent frame.
I ended up cutting the bracket down almost a 1/4" on one side to get it to fit. It did shift the fan blade over, but it still clears the frame.
I don't have a glue gun so I used angled spacers and mounted the controller with nuts and bolts.
#36
Posted 20 September 2015 - 08:48 PM
Nice job and under $50 ! How is it working and can up post a link to the controller you used. I might add a front vent.
#37
Posted 20 September 2015 - 09:58 PM
Infinite speed settings and no buzz.
Item # 360762240584
View item:
6V-30V 200W PWM DC motor Speed Controller Module with Switchable Potentiometer
(Can't seem to get the link to work, but the title should get you there on eBay. The seller is "axeprice")
Edited by EDR, 20 September 2015 - 10:13 PM.
#38
Posted 27 September 2015 - 12:09 AM
So anybody else do this mod?
Is Item # 360762240584 the way to go for a factory fantastic fan?
Would this be comparable? http://www.ebay.com/...=item3cddb007b0
#39
Posted 27 September 2015 - 01:09 AM
Would work, might be quite or not. Item number 360762240584 is less money $7.32 and has a reversing switch. You could wire in the switch to the one you have already. How do they make that for $7.32.
#40
Posted 27 September 2015 - 01:50 AM
Good enough. Ordered!
Also tagged with one or more of these keywords: Fan, Fantastic Fan, Modification, Speed adjustment
Trucks, Campers, Gear Forums →
Truck Campers →
Four Wheel Camper Discussions →
Power for fan over bed ?Started by BMH44 , 17 Apr 2024 fan, wiring |
Truck Campers →
2009 Eagle swap out to a fanStarted by Greeneggsslc , 24 Feb 2020 fan, upgrade, prewired |
Truck Campers →
Hawk - Shower repair and Fanstistic FanStarted by wpage66 , 22 Oct 2016 repairs, Shower, vent, fan |
