Beautiful Morning Sunrise....
Travel Light, Travel Fast!
Weighted our van this morning, fully loaded for travel (Except clothing and food) and weights in at 7320 lbs total, GVRW is 8550. Not bad as that includes the roof rack, 34" tires, full 47 gallon fuel tank, suspension with 2" lift, ladder, rock sliders, fridge, bed, cook gear, etc etc.
Just a reminder to keep weight in mind when building your setup, the trip is much more enjoyable and safer when the vehicle is light and handles well
2017 Sprinter Wet Wiper System Upgrade!
Seen this upgrade in a previous post and did it to our van today, great upgrade! For this install you install Mercedes OEm wet wiper arms and blades from a 2019-2020 Sprinter. The washer fluid travels up through a hose on the arm then into the blade itself where it squirts out small holes that are drilled all the way down the length of the blade.
The OEM washer nozzles on the 2017 clip onto the arm and they break off super easy, especially when washing the window with a squeegee. They also don't spray where you actually want the fluid to go. With the Wet Wipers the fluid is evenly distributed onto the windshield
Install took maybe 10 minutes, pretty happy to have this addition on the van.
Total $175. If you want to order this setup here are the Mercedes Part Numbers.
Wiper Blades (Set): 9108240100
Wiper Arm Left: 9108205600
Wiper Arm Right: 9108205700
New parts.
The washer fluid travels up the wiper arms through tubing then into the wipers themselves, there are holes all along the wiper blade that the water squirts out of.
Photo of the wipers/washers in action.
Video of the washers/wipers in action.
https://youtu.be/BRB4q6JR25A
Hodakaguy
Edited by Hodakaguy, 05 May 2022 - 02:56 AM.
