So Saturday arrived and I started out by removing the driver side panel. Quite easy just remove a couple dozen screws, don't bother pulling the staples yet. First set of screws are for the bed extension - why they are not painted like the rest is beyond me. The next are under the Velcro strip for the bottom of the Thermal Pack. I exposed the first one, but not the rest as there are many staples so I just pushed the square drive tight into the screws and backed them out. I removed the visible screws on the sides of the panel and then used a putty knife to pry the panel away from the aluminum frame. Now you can put a slight bent in the panel (it's doorskin) and remove it. Now is the time to pull the staples out of the wood. If you attempt to remove them before popping the panel off your pulling the staples out of the frame and wood so it's more time consuming and you damage the panel.
Edited by Captm, 01 February 2014 - 03:36 PM.
