Jiggers. Our battery compartment is vented too, and the area sealed as described by others above. Never noticed that before. But the vents don't look sufficient to cool very much in hot weather, it seem more for venting gas. On the other hand, in very cold weather it may be enough to cool a lithium battery that's not being used all night below freezing. The top of that compartment is somewhat sealed too.
Maybe it's wise to get a battery with the heating feature. Or plug the venting in that compartment, and maybe vent to the inside so the battery stays a little warmer at night.
Double issue....'too cold' my BB BMS will not allow battery to charge; but then again I can drop the SOC to about 20% before BMS shuts it off [charging and use are different issues]....so I have 80aH available between charges...'too hot' and life of battery decreases....soooooo, you can use the internally heated BB; on at 25-45 degrees [which we have], to charge the battery even if battery compartment is well below freezing [not nice in Hawk at those temps; but furnace keeps it cozy if I am in camper] such as when I am out skiing and ambient is down to 15 degrees or less, heated battery keeps the solar panels charging battery; I do not leave furnace/propane on when I am out of Hawk.
'Too hot'? well not a lot you can do about that; install a fan, but it is not the battery generating the heat but outside air, so fan will just circulate hot air assuming Hawk and outside temps are the same. A few campers have air conditioners; but honestly you need 110v hookup for those.
Without a heater in battery [BB] you could leave tie down doors open and run furnace to heat area of truck bed around battery box....not very efficient...or cut vents in battery box inside the camper to let in furnace heated air...still not the best solution.
Edited by Wallowa, 05 December 2022 - 11:13 PM.
